In my never ending quest to find covers for my sleds, I have finally decided to give up and make my own. I'm tired of using old bed sheets as a cover for my Liquifire, so this is the solution I am working on.
The first part of the project is to make a custom fit soft cover for both of my fire series sleds and for my 77 sled. The material I have selected for this cover is Tech Fleece 200. It is a very soft material, and it has some weight to it, so it should do a good job protecting the hood. If you have a lot of time and money invested in the paint job on your hood this is a good way of protecting it.
The cover for my Sportfire is going to serve as a pattern for the whole sled cover, the 77 will be based off of this cover also. John Deere did a real nice job on making this cover, but I think there is room for some improvement.
The main areas I would like to improve on.
1. Choice of material - There are some newer materials that are available now that were not available 30 years ago, I will highlight my front runner as far as materials in the end.
2. Fit - Fit is near perfect but it can use some improvement in the windhshield handlebar area. I am also going to slope it a little different from the windshield to the back of the seat, so snow doesn't sit on the seat.
3. Stitching - The covers I have are single stitched seams. I would like to go with double stitched seams, and finished hems.
4. Tie downs - There seems to be room for improvement on the way the cover is held into place.
5. Reinforcement - The cover I have doesn't have much reinforcement in key areas where abrasion could wear through the cover. This will be improved.
As of right now the front runner for the material that I am going to use is WeatherMax. This is a short blurb from there website:
A unique engineered polymer material designed specifically for constant outdoor use. It is extremely UV resistant and extremely resistant to fading and color loss. This material provides breathe ability, abrasion resistant and eliminates sagging. This material is also water repellant and mildew resistant, and unlike coated fabrics will not crack in cold weather. Due to this material’s special formulation it cleans easily with mild detergent. Mildew stains are easily removed with a solution of 1 cup of bleach and ½ cup of mild detergent in a gallon of water, without affecting the color fastness of the material. Eco-friendly WeatherMax fabric is 100% recyclable.
Polyester and Acrylic Polyester are some of the leading materials for making covers. Here are some of the numbers comparing WeatherMax to Acrylic.
Abrasion Resistance - WeatherMax 600 cycles to 90 cycles for Acrylics
Hydrostatic Pressure - WeatherMax is 67% more water resistant than Acrylics
Fabric Strength - 390 lbs, this is the number that determines if a fabric can with stand trailering.
Tear Strength - WeatherMax is 20 lbs. Acrylics - 9 lbs.
Colorfastness - 5 years.
Temperature - Tested to -41 degress, with no cracking.
So far it's a front runner but the decision has not been made, I have a few more to look into.
Early estimates would put the soft cover at around $50 and the complete cover at around $150 to make. Will these be available for sale? Not sure yet, labor will be a factor and also how well they turn out. If anyone is interested let me know. I will post some pics when I get the first prototype done.
